The value of unacknowledgement timerID returned a NULL while trying to create a LACP timer. The timer is needed to detect liveness.
Check if aggregator is set. Also, check if the connection to the VLAN mgr is maintained. Otherwise, reboot switch. show switch show lacp
Critical
Failed to create the unacknowledgement timer for LAG with group Id: %grpId%
| Name | Type |
| grpId | String |
